TwinTurbo.NET: Nissan 300ZX forum - 5spd swap question - clutch line mounting on frame rail
Subject 5spd swap question - clutch line mounting on frame rail
Posted by 91Z32TT on January 09, 2011 at 2:24 AM
  This message has been viewed 100 times.
Message The Z I'm working on has no bracket on the bottom of the frame rail for the clutch hard line to soft line transition. I've used all the OEM equipment from a donor car, so the factory lines are in place, but there is nothing to brace the line from the bottom. Would there be any problem with connecting the line as is, or would continued use possibly flex the line and cause problems down the road?
I'm kicking myself now for not drilling the spot welds out of the bracket from the donor car before we got rid of it, but what's done is done.
Thanks in advance!
